e-class merc back glass(6 times)
Guest tintec
:thumb
I'v done 1000's of these cars...I know what your talkin about.
steel wool the backglass....#0000...scrub it real good until all the high and rough edges are off the defrosters.
I would WET shape it...dry shaping .... :DD ... if you do it dry ....you will battle the bleaders. :DD
Happy Tinting
:DD
Guest tintec
I did steel wool it,I always dry shrink,wet shaping just soak it with j&j soap and water, under and over the film and h anchor it is this correct?? :thumb
yep...seal the bottom edge ....and chase that bubble with the heat gun. after doing that I would trim the film, and re-heat the bottom edge..then cut the final pattern......this will result in having no fingers after the film is installed..... :thumb
I feel your pain....thoes older benz can be a pain in the buttox.... :DD
:DD
