  • Replies 70
Guest vclimber
As for the IRs 70 can it really be dual pane safe with an absorption of 54%????
If the glass is good and there are no major external issues, it should be fine. Will Geo warranty it on IG? That would be your concern. :evilgrin
I emailed them on this already, just waiting a response.
Guest darkdan
Yes, they warranty it on low-e.
They warranty the Geo 30% also!
I hear last year they had zero glass breakage as a result of thermal shock related to the film (ie, glass broke, but it wasn't the films fault, stuff like hidden shells).
Guest vclimber
On the IRis 70, have you guys notice a bit of hazy look to it? :eyebrows or is it just me?
That's common with these types of films.
Yeah inherent trait... it can be either the IR absorbing dye, the poly doing that.
Guest vclimber
I wouldn't go so far as to calling it a "haze", but rather the window "glows".
Hard for me to explain how I perceive it.
Vista has an IR film V-75 IR and to my knowledge it is using IR dye. It glows alright! :eyebrows So much so that we have stripped off just about every sq ft we've every installed. Most customers describe the effect as "haze."
I just got my information packet and the numbers they have on the sheets is on 3mm glass which is just under 1/8 inch.... have they changed it from what you have seen then Vclimber?
darn it....the IRis70 is on 6mm glass....didn't read far enough.....
how much difference will that make?
    2. 3
    4. 3
    6. 4
    8. 4
    9. 4
    10. 4
