last series t-bird
Guest DENISCARS
Guest DENISCARS
has anyone had trouble doing rear windows of this model after shrinking I'll make small cuts along the corners about 2-3 inches on the sides down to maybe 5 inches toward the taillight. so when I'm squeegying the film the fingers I've made act like anchors seems to work for me every time. just .02 cents worth
Guest Sprinter
no cuts here just leave the outside edges hang for a little while then squegee and use alittle heat, works better with a blue max more pressure on the tint down there.
Guest DENISCARS
yup I'm yackin' about that POS the finger cuts I talking about are when looking at the back glass from the outside. from the bottom corners work up about 3-4 inches making small slices maybe only 1/4" long spaced at 1" apart then on the bottom edge work the same way toward the middle for about 4-5" those small cuts will work like fingers to hold down the film. so then I wont need to make relief cuts on the defrosters hope that explains it better
