Tiny air bubbles all over my window after tint job
Guest Fman
8
8
LLumar, 3M and Solargard have in the industry as far back as the genesis of window film mid-1960's). Solargard is the younger of the three and all others came to play in the last 20 or so years. I've had all three on my vehicles over the years and my current is 3M Crystalline on my Jeep since 2015. It still has stable color, scratch coat is holding strong and impeccable adhesive clarity. Never been garaged. My choice toady would be 3M or LLumar.
