2000 CRV BG
FBO
Do you guys remove the struts? if so, how do you keep it up to install the film? Thanks.
Yes, Remove struts.....
The answer to Your second question.... "Say Man, Can You hold this window up for me for, like, 5 minutes?" :barf
Look at the nuts that attach the struts to the glass, a lot of times the pot metal is starting to strip out. if that's the case, I think they are $10 from honda, tell the customer that if he gets them, you can install them while you are tinting the back window.
for removing struts I found that a prop stick works really well to hold the glass up after you install the film. You can find them on every tool truck and some tool store's.
They cost around $30 to $40 from the tool trucks, I think I got mine from the cornwell man.
If I get a chance I'll put a pic of it up here. :barf
Guest Malcolm E Boo
I have a bungy cord contected to a hook on the ceiling that holds up b/g's that have the struts removed.
Now that is a good idea :dunno
So how did it turn out FBO? I did one of these the other day, did you end up removing everything (wire tunnels ect) or tint with just the struts removed?
    2. 4
    3. 4
    4. 4
    6. 4
    8. 1
    9. 3
