13
4,171
4,171
Cracked glass
Question about VLT variance
I just did a minor search on google and found this about the tinting laws of Illinois State. Windshield: Non-reflective tint is allowed on the top 6 inches of the windshield. Front Side windows: Must allow more than 35% of light in. Back Side windows: Must allow more than 35% of light in. Rear Window: Must allow more than 35% of light in. Please keep in mind that it is only for Sedans, if you have SUV then the law is different. -
Electronic Malfunction From Tint?
This can be an issue with all makes and models, in fact the more electronics that newer vehicles contain, the more likely something will eventually go wrong. I personally worry most about tinting front windshields as we can't always see where our soapy water will end up behind the dash. -
Has anybody tried these and whats your opinion of them? -
Is this still an issue with 2023 and 2024 models?
