How can I fix this
You need some really strong glue mike. If you have some black 995 around. You might be able to reglue the foam to ths sides of the plastic form with that. Also you might try Windsheild urethane. That stuff will glue anything together. Put some down each side, and tape it back tight with masking tape.
Yea I have some Dow 995.... :D
I think I may have to get some of the old foam out before I try any type of glue or 995.
I like the idea of the bracing Tom, I did not really give that a thought.
