HI GUYS HELP ME..
Guest BigZ
  • Replies 23
We remove the shock struts, dry shrink the window, cut the pattern, install film, then cut the circles out when the film is on the inside. If you cut the circles out on the outside when you install it they tend not to line up after install. You can dry fit the film on the inside and pre cut the holes first before installing but it takes a little longer that way.
:thumb I agree with "pro tint"
We remove the shock struts, dry shrink the window, cut the pattern, install film, then cut the circles out when the film is on the inside. If you cut the circles out on the outside when you install it they tend not to line up after install. You can dry fit the film on the inside and pre cut the holes first before installing but it takes a little longer that way. :lol
after you have done a few of them you will be able to do it with out first removing the struts, just cut around them then do the double cut on the inside
