very cold install
I have to install 4mil security film on all the glass sufaces inside a seafood warehouse. It is 32-34 degrees at all times. I'm concerned that the moisture between the film and the glass will freeze or never evaporate. will the film even stick? I was thinking of using an alcohol in my slip solution. It has been done at other locations, from what I've been told. Anyone here familiar with this? Also, I need some gloves I can install with in the cold. It took ten minutes to warm up my hands after just measuring the job. Any recommendations?
  • Replies 25
Is one side of the glass more suitable for tinting than the other?
I wouldnt use gloves, you need the dexterity, but maybe keep a bucket of hot water beside you to keep dipping into
They are offices inside the warehouse, and I have to do both sides. Good idea about the hot water for the hands.
Guest thatsnappyguy
I hope your charging accordingly for this extreme temp tinting. I have tinted with gloves in the past for exterior winter tinting and got the hang of it quickly.
