2008 Chevy Malibu door rubbers
pbalentine
Do you guys pull the rubber seals that surround these roll ups? They're similar to the seals on the impala, which I always pull, but with these removed the window top edge would have nothing to go inside when rolled up. I ended up leaving them in just to be safe.
I had foam in the rear corner of one of these that had been sticking.out atleast a half inch in.width and maybe 4 inches wide.... it made me think that the back glass was replaced, although the owner says it has never been replaced...
just curious if anyone has seen this??
must just be poor installation from factory I assume?? I tried to use the bulldozer to push it back down but it would keep popping back up.... I ended up getting one of them white plastic slip thingys and slidding the tint behind it
See it all the time on those... Some worse than others.
