Tips for 2013 Mercedes e class coupe?
cannot trick these windows..just cut out your pattern, tuck the gasket down and stick it..if the pattern is cut correctly it will leave just the right amount of gap at the top
YES, you can trick these..I do a couple a week it seems. It's just like any other trick window. You have to push it up in the there a little farther for it to "click" and when you got to drop it back down, turn the ACC on in the car then pull the handle for it to drop. As far as the back window, its simple..
kinda what i meant by two clicks
