SolarFX Subscriber Raffle- 40"x100' Ultra Series Automotive Fi
4,178
What did you tint today?
Thanks for the reply! I will see what happens. I tested the paint on a scrap of PPF I had sitting around, the it seems really secure. Just for perspective, I attached a photo of my goof. It really was a small divot, just bugged me that I did it at all. I did place a very small bit of paint on the top of the exposure. Living in MN, rust is always the concern, so I am hoping I have this sealed. While I know that PPF can't heal a cut like this, it was very flat so the exposure should hopefully be minimal. (What looks like a fold is the reflection of a seam in the ceiling) -
Sometimes customers show up with a few chips but no touch up paint to fix them before the install. I have had pretty good luck putting a few drops of touch up paint in a syringe and injecting that under the film into the chip once they come back with the paint. You might want to try that when that paint on top washes off. -
flat glass commercial and residential installer needed New York / New jersey area
Looking for a flat glass installer with experience NY / NJ area call 212 401-1228 -
Just out of curiosity - how much do different manufacturers pay for labor for warranty work on solar and safety films? Thanks! -
I would go at it with a few chemicals to see what might work and definitely have some steel wool like @Tintguy1980 mentioned. Wouldn't hurt to tape off the edge of the frame and use some plastic sheeting to keep the chems off the paint and rince everything after. Chems I might try: 1. 3m adhesive remover in the red can (not aerosol) 2. Spot Shot 3. Rapid Remover Or maybe just a tablespoon of soap in a bottle of water and a scraper blade. Alcohol won't always do it depending on what the adhesive is polar towards, and can sometimes seem to harden it. If you are BLADING THE GLASS, make a conscious effort to ALWAYS HAVE ONE ARM BEHIND YOUR BACK. Failure to do so can send you to the hospital quickly...this was a tough lesson that I and many others learned the hard way!!! -
Looking to hire a few window tinters and wrappers for the following locations: Palmdale, CA And Las Vegas, NV Fulltime or Part time. Compensation will be discussed in person.702-909-0202
