Where do you buy tint in UK? Where to buy polyurethane tint for headlamps? Thank you. -
Tint racks
Hey everyone, you have probably seen my ad on the side bar for my tint racks. Well i have them marked at 15% off on my website right now till June 14th I’ve also made a quick video showing how the racks are made. I wanted to explain why I think my racks are a better choice than others on the market. Here's why my racks stand out: Quality Material: I cut my racks from 1/8th inch steel, which is sturdier compared to some other brands (you know, the ones that rhyme with "Ruffalo"). In-House Production: All fabricating and powder coating are done in-house, which helps keep pricing low for everyone. Customization: Need a custom size? No problem! I’ve made racks that fit both 10-inch and 17-inch rolls for different materials. Affordable Pricing: My pricing is much lower than other brands because I handle all fabrication myself. You’re not buying from a large company that adds a markup for reselling someone else's racks. Check out my WEBSITE for more details and to watch the VIDEO. Thanks for supporting a small business! -
4,177
Dagumheehawthrillbillys! HP20/10 Alligator console, five point seats, 37s on 24" rims, draft pipes...and on and on... I guess I didn't price it high enough to chase it away -
Company Background: Auto Tinting Austin LLC is a 5-Star rated Window Tinting business established in 2013. We offer high quality products, expert installation and excellent customer service. We Offer: -A Very Positive and Supportive Work Atmosphere -Consistent Work Year Round -Very Competitive Pay -Air Conditioned Bay -Tool Allotment -Snacks and Lunches -$1000 Sign On Bonus -Willing to Assist in Relocating the Right Candidate -Porter and Tint Shop Support Team -Plotter, Bottles, Shampoo Etc All Provided Job Duties: Seeking experienced window tinting technician to install automotive window film. Experience with plotter and hand cutting. Ability to operate manual vehicles for parking and moving. Will work with a helper team that can step in to cut film, move cars, remove film. Positive atmosphere. Hours: Schedule is open Monday-Saturday. Pay: $1000 Sign on Bonus! $1000-$2500+/Week Full Time, $300-600/Day Part Time ---BASE PAY AND TIPS!! Please call to schedule interview. 512-956-8468 Manager: Jody/Aric Auto Tinting Austin LLC 1601 Bench Mark Dr. Ste C Austin, TX 78728 www.AutoTintingAustin.com Job Type: Full-time Job Type: Part-time Pay: $1500-$2500+/Week Full Time, $300-600/Day Part Time
