Create a cool Lamp in 5min
Hi everyone,
A little trick to create a practical Lamp for working on your rear windows.
You will need a 47in regular fluorescent lamp
An empty roll of 60in film ( in translucent plastic )
An electric cable with its plug
4 screws
Cut one or both of the box roll wedge, depending if you want the Lamp be able to stand verticaly
Cut a 49,6in piece in the plastic tube
Make a 1.4in nick a the bottom
Connect the electric cable to the lamp, and insert all through the tube
Place the cable through the Nick and place a wedge and 2 screw to make it stay in place
Put the other wedge in the way to block the neon strip and fix it with the screw.
That's good, you have spend 5 min to make a cool lamp for cutting film on your rear window, enjoy it ;)
( sorry for my english, tell me if something si not clear ;) )
Now I need a few white cores and a bigger christmas list.
Pretty up the ends and this would be a very cool lamp for many areas not just for work use!!
Even as is it would be an easy cleanup if it ever fell and the bulb broke!
Yeah, I spied a 6" white core on a roll of PPF the other day while visiting and immediately saw a three-tiered hanging lamp could be fashioned from it.
    2. 5
    6. 3
    7. 3
    8. 4
    9. 0
    10. 6
