bus tint! how would you charge this? help
  • Replies 34
Do you mostly do auto or flat glass?
I do almost all auto. Done flat glass maybe 3 times.
If you're going to have a helper for the whole job , put it up like a residential job.lightly mist the film and have your helper peel it , trim it on the .... is it glass or plastic?( Hence the suggestion of making a pattern)  , If it is glass just trim it once the piece is tacked up , squeegee , boom your done. :D
So are you suggesting misting a larger than the window piece of tint, slam it on top edge first, push out to each edge of the window seal then trim it?
Yep, but I wouldn't slam it up ,you might crease it   :lol .Depending on how the seats line up with windows you might find it easier to precut on the outside as some have suggested .
If you're lucky you'll be given a 40" inch roll. This will be almost exactly your window height. Most of your windows will be the same size, cut them slightly over-sized straight out of the box and trim your excess  as HG suggested.
Do you have gaskets or a black ceramic edge?
Its gaskets I've been told
