bus tint! how would you charge this? help
  • Replies 34
Unless there is an emergency door you can double cut your patterns, saves time.  Other than paying a little above to the helper I would not do it for less than $1,400, even with them supplying the material and a helper.
If you're going to have a helper for the whole job , put it up like a residential job.lightly mist the film and have your helper peel it , trim it on the .... is it glass or plastic?( Hence the suggestion of making a pattern)  , If it is glass just trim it once the piece is tacked up , squeegee , boom your done. :D
