Film on Film, will it stick?
  • Replies 36
I have always shied away from film on film per factory recommendations , ie : the hard coat "could" react with the adhesive on the second layer. But with all the "success" stories I might think again.
I think it was someone in the film industry that explained it to me like this.
Film works in certain direction. If you install film on the opposite side of the glass, it doesn't work the same(similar yes, but not the same)
If you layer film, you are not creating one piece that works properly, you are creating two pieces fighting each other. The layer closest to the sun will go bad faster than it is supposed too. The layer closest to you is causing the other layer to go bad.
I have also seen the two pieces slide after install, on roll-up windows.  The layer closest to you will slide over time.  :twocents
we do it all the time but it has to be done the right way.  and we never warranty it
the first piece that is applied has to be bigger than the 2nd piece.  if the 2nd layer is larger there will be an air bubble line from the overlap.  if there is any overlap; after a long amount of time (my experience is 5 years) it will develop fingers.
so cut the first layer larger than normal on all sides.  on the second layer cut it a tas smaller and leave the tiniest gap at the top edge.
we do the same when applying a sunstrip to a tinted windshield
If you layer film, you are not creating one piece that works properly, you are creating two pieces fighting each other. The layer closest to the sun will go bad faster than it is supposed too. The layer closest to you is causing the other layer to go bad. :facepalm:bs:lolsign  :console
I have also seen the two pieces slide after install, on roll-up windows.  The layer closest to you will slide over time.  :dittoBut really poor adhesive grab.
If that were so you would see only one ply films produced.
    5. 4
    6. 0
    7. 1
    8. 1
    9. 6
