Corny keg hose
14 hours ago, Tint Slayer said:
Anybody make one of these on their own? The cornelius keg itself can be found pretty cheap and it has fairly basic attachments (air valve, hose), anyone give it a shot?
Yep...I have built several.  Got 5 tanks for $20 once.  Spent $38 for 100' of braided hose...the fittings to attach the hose to the tank outlet was the most expensive part if I remember right.
I found mine in the ditch frozen in the ice(1/4in) with just the top sticking out
Needed some pin holes welded up and got a used threaded fitting($5) and coupler($7) from the brew store then a $4 pressure guage and air fitting($2) used air hose and spray nozzle $?
In the end i wasted more time than it is worth running around to find all that and the fix up welding and some threading that a buddy with machine shop helped me with but its okay to have and still havent lugged it to any flatglass job yet lol
On 8/29/2017 at 2:21 AM, DOOTINT said:
The cheaper clear hose didnt work with 100psi(bloated) but worked fine with my pump up sprayer
I used a old airhose for the corny
how did you rig that pressure guage ?
I removed that side metal fitting coupler and ran a pipe tap thru the hole that fit the pressure guage pipe threads and i looked at various guages to find a flush mounting one that was below the handles(harbor freight)
Edited by DOOTINT
    2. 1
    4. 1
    6. 1
    7. 8
    8. 8
    9. 3
