2018 Tesla model x
THE TINT GROUP
flip door latches too pop up windows. Once windows are finished flip latches back to normal position. Take notice to the red light on the side of door if that light is on the latches are fully flipped to the correct position. Manually push the doors shut completely. Walk away from vehicle with key fob in hand till the car locks itself. Then walk back to car doors will open a little bit. get in and pull handle to activate the automatic close and that's it.
As mentined doors need to be reset.  Once you pull the handle and the lock goes back you still need to rotate it some to get the red door light to turn on.  Once the light is RED, you can manually shut the doors.
Also, there are 2 sets of 1/4s behind rollups and there are a small set 22”x12”  sunroof windows above rear rollups, so charge right. The bg spoiler was in the way at bottom, so i shrank bottom up to spoiler, did final trim, then shifter film up, and shrank the last 3-4 inche of the bottom.
