What's the reason for some vehicles getting glare on the defrost lines?
Hi All, How reliable are manufacturer provided Technical Specifications for Window Tint? I've compiled a list of tints based on manufacturer provided technical data & looking for insights into long term ownership with respect to scratch resistance, colour fade, impact on driver visibility, etc. Basically, I'm looking to narrow down the choice of products but different installers recommend different product lines. 3M Ceramic IR Series IR 35 for Front Side Windows 3M Ceramic IR Series IR 25 for Rear Side Windows & Rear Window ASWF Retro IRP 35 Nano-ceramic Black Armor Elite Nano Ceramic Series E38 for Front Side Windows Black Armor Select Ceramic Series S38 for Front Side Windows Black Armor Select Ceramic Series S20 for Rear Side Windows & Rear Window Llumar MEP Ceramic CNP35 for Front Side Windows Llumar MEP Ceramic CNP20 for Rear Side Windows & Rear Window Ultragard Fusion NX 38 Nano-Ceramic for Front Side Windows Ultragard Fusion NX 27 Nano-Ceramic for Rear Side Windows & Rear Window Ultragard Genesis IR ultra ceramic nano IR40 for Front Side Windows Ultragard Genesis IR ultra ceramic nano IR25 for Rear Side Windows & Rear Window Ultragard Genesis IR ultra ceramic nano IR33 for Rear Side Windows & Rear Window Solargard VTX Pro Premium Ceramic Window Film 35 for Front Side Windows SunTek CIR (CeramicIR) CIR40 Black for Front Side Windows SunTek CIR (CeramicIR) CIR 30 Black for Rear Side Windows & Rear Window SunTek CIR (CeramicIR) CIR 20 Black for Rear Side Windows & Rear Window SunTek CXP (CarbonXP) CXP45 Black for Front Side Windows SunTek CXP (CarbonXP) CXP25 Black for Rear Side Windows & Rear Window SunTek CXP (CarbonXP) CXP 35 Black for Rear Side Windows & Rear Window SunTek Evolve 35 ceramic for Front Side Windows SunTek Evolve 20 ceramic for Rear Side Windows & Rear Window SunTek Evolve 30 ceramic for Rear Side Windows & Rear Window Rayno Phantom S5-35 Nano Carbon Ceramic for Front Side Windows Rayno Phantom S5-20 Nano Carbon Ceramic for Rear Side Windows & Rear Window Rayno Phantom S5-30 Nano Carbon Ceramic for Rear Side Windows & Rear Window Rayno Phantom S7-35 for Front Side Windows Rayno Phantom S7-20 for Rear Side Windows & Rear Window Rayno Phantom S7-30 for Rear Side Windows & Rear Window Rayno Phantom S9-35 for Front Side Windows Rayno Phantom S9-20 for Rear Side Windows & Rear Window Rayno Phantom S9-30 for Rear Side Windows & Rear Window ASWF Carbon 35 for Front Side Windows ASWF Carbon 28 for Rear Side Windows & Rear Window ASWF Carbon 20 for Rear Side Windows & Rear Window ASWF Dimension IRP 40 Nano-Ceramic for Front Side Windows ASWF Dimension IRP 25 Nano-Ceramic for Rear Side Windows & Rear Window ASWF Excel IRP 35 for Front Side Windows ASWF Excel IRP 25 for Rear Side Windows & Rear Window ASWF Dimension X DX40 for All Windows -
Wet shrinking has advantages but it also has limitations. I'd learn a good dry shrink technique, then follow up with a wet check. You can get a lot more shrink into a piece doing it dry with a lot less stress on the film.
