tintittowinit Posted February 19, 2020 Report Share Posted February 19, 2020 Hi just wanted to ask, is the difference really noticeable at night the reflectivity, between a 17 interior vlr between a 11 vlr film. I'm looking at comparing NV15 with Optishade 15? Like for the common client if the difference between the two is noticeable. Would you know? Or does anyone have experience with a similar tint? In comparison? Link to comment
Ryker Posted February 20, 2020 Report Share Posted February 20, 2020 That is going to be a very small difference in what you see. Link to comment
addicted to tint Posted February 20, 2020 Report Share Posted February 20, 2020 11% interior reflectivity is virtually the same as unfilmed glass. 17% while not much, will have a bit more sheen. Have samples of each put up side by side and view at night. Link to comment
tintittowinit Posted February 20, 2020 Author Report Share Posted February 20, 2020 Well I'm trying to compare NV15 to Optishade 15 from Avery. Have any of you tried Optishade 15 from Avery? I'm planning to use it. Link to comment
TomTint Posted February 20, 2020 Report Share Posted February 20, 2020 We have installed DR15 from Lulu, NV15 from MMM, Opti15 from Avery...and DR15 from Global..... Lulu has a funky silvery look at night looking out, MMM looks like a oil slick looking out at night, Averys is better than both of those. ...But Globals may be the nicest neutral looking DR on the market. Link to comment
Ryker Posted February 20, 2020 Report Share Posted February 20, 2020 Global DR is a really nice black interior for sure... Is TFI, oil slick, still an issue with LED light? Link to comment
tintittowinit Posted February 20, 2020 Author Report Share Posted February 20, 2020 (edited) Thanks Tom! Oil slick... that must look bad... How about the Optitune 20? I was also thinking of that since the VLR is a low 14% and I've heard it looks nicer than Optishade. Which is your pick? From Optishade and Optitune. Also thanks for the advice before! Did the exterior. looked good and sealed it good 1/2 all around. Edited February 20, 2020 by tintittowinit Link to comment
TomTint Posted February 21, 2020 Report Share Posted February 21, 2020 18 minutes ago, tintittowinit said: Thanks Tom! Oil slick... that must look bad... How about the Optitune 20? I was also thinking of that since the VLR is a low 14% and I've heard it looks nicer than Optishade. Which is your pick? From Optishade and Optitune. Also thanks for the advice before! Did the exterior. looked good and sealed it good 1/2 all around. ...My choice would be Global...I wouldn't even bother with the others. Link to comment
tintittowinit Posted February 21, 2020 Author Report Share Posted February 21, 2020 10 minutes ago, TomTint said: ...My choice would be Global...I wouldn't even bother with the others. Even with the higher vlr? hmmm Link to comment
TomTint Posted February 21, 2020 Report Share Posted February 21, 2020 11 minutes ago, tintittowinit said: Even with the higher vlr? hmmm You are splitting hairs with the VLR#s... it's more about the reflected color and distortion...or lack of it Link to comment
