03 accord 4 door
Guest thetintshop
Guest TheStott
I used this method yesterday on an '05 Accord. Turned out awesome. It was a little time consuming. It looked like I was going to break the window getting it out of there. Once I put the windows back in, I just had to make sure all the rubber gaskets were where they needed to be.
Bryan
  • Replies 32
Guest Reflexxions
It's at the very top of the door under the rubber seal , pull up the rubber above the post of the window and you will see a torx screw or a phillips screw it could have either one .
