Backglass shrink *video*
didn't look too bad.....the fight with the bottom inch or so on the first section could be helped by changing the angle on the gun and just blowing a bit of heat under it then back on top. The GLASS is acting like a heat sink and pulling the heat away from the film.
That is why I use the over and under together or hold the film up OFF the glass on the top.....it will shrink much faster and easier....
Originally from TN....recently located to TX.
camera is sony cybershot 12.1MP T90
using ST carbon
I usually just shrink pass the dot matrix and stop, whatever beyond that doesn't make a difference. Also, I do pull on the film only when I have to and I do the over & under on certain cars. check other videos too....this camera is awesome :coffee
