Door panel protector
Anyone know of a good door panel protector? I see soakshield makes one but I can't find anyone that actually sells it. Found a random Facebook page called door panel protector as well.
Thinking outside the box; this may serve the purpose. You might be able to reuse from car to car IF, you can put sheets aside intact and not stuck together.
https://www.lowes.com/pd/200-ft-Clear-Carpet-Accessory/4129492
I would use Glad Press N Seal on the top edge.   No bulk of a towel.   and since it is not the full height of the door panel, on the bottom half, just add in some plastic drop sheet or garbage bag.
The press n Seal will stick to all surfaces and the garbage bag,  then all the water will run off the door.
