Personally knowing what it's like in Vegas when it's hot, I would stir clear of any film TSER performance value less than 60% or a solar heat gain value greater than 40%. Prestige does not fit this and would be a big waste of good money. Huper Optiks' ceramic products have high solar energy absorption rates, so in hot environments these kind high absorptive films run counterintuitive to the use of the product while using air conditioning to cooling the interior. High absorption on the inside pane, where most films are applied will radiate that absorbed heat toward the room. Outside breezes across the exterior surface of the window will not be as effective in cooling down the interior than say a low absorptive film, high solar reflection film product. In this case, low absorptive/high solar reflection products you should entertain either 3M's Night Vision15 or NV25, Vista Film's Dual Reflective 18 or DR 28, LLumar's DR15 or DR15 (which closely matches 3M NV), Madico's Optivision in and around the same number assignment. The numbers assigned to films represent the visible light transmission of the product. When a dealer comes out to assess and likely have and leave samples, use the samples as sunglasses by wrapping over your eyes a viewing out and in the room. This gives you a more precise idea of what the film will look like once applied. A small sample placed on the glass will always appear darker than having the entire panel tinted. Good luck. -
8
Applying PPF profitable?
8
High speed material feed
The Graphtech plotters are all about the same from 7000 to 8600. I doubt that the machine was the problem If changing software fixed the issue.
