By the way how much coverage would I achieve from 1524mm x 3000mm (i.e. 60" x 118") -
thanks for the input, going to try the nt blades -
We have been using olfa blades forever but in the past year we have noticed the quality of the blades is not the same as it used to be. Blades are not as sharp and pressing harder is starting to etch the glass on certain vehicles. Would like to know if anyone else is experiencing this or is there a better brand ss blades that you have been using that is a better trusted brand.
