2008 Escalade Glass Size
Guest scottydosnntkno
im a panel puller and I drop em low. you can still line it up low just not too much. the small side of the rear door on the inside is different than the outside, so check it out b4 u cut. its also hella tight back there.
I'm a tucker so I usually just tuck in under just a tad. Thats why I like GM's with the loose seals, no worries. The small size of the rear is the back bottom corner right?
yeah. u got plenty of room on the bottom. u wont need to tuck the rubber at all.
once u see the car youll know what to look for.
20 fit the rear too just be careful lining up cuz the privacy is pretty dark
thats what I was figuring. I have a handheld fluorescent that I use for trimming the darker films on back glass's that I was planning on using. I figured shrink wise it doesn't matter if your off a little bit, but cutting it would make more of a dif.
