What's the best option for cutting this?
I've spoke with Decorative Films about cutting it to specification. Sounds great but just wanted to see other options. It's for a contractor so it has to be somewhat cost effective. If you were to hand cut this would you install and solid piece than trim everything? Or Cut everything and install piece by piece. The door wouldn't be bad to hand cut but the windows seem time consuming. Thanks for the help.
  • Replies 26
When everyone says "plotter," does that mean it will cut all one piece or individual strips?
you have to put the measurement in the computer, film roll size and all, and the computer cuts it for you based on the measurement you put in. Weeding the access will be tricky depending on how you do it. Measure twice, cut once. Good luck
