Blade Angle?
What angle Blades do you guys use for window tint? Im having a terrible time dialing in tint on a Mutoh 54" using a 45 degree angle blade. Its either too deep, and screwing up my run, or not deep enough and i have to re trace everything by hand.
Ps. Sorry for the repost Tintdude. You can delete my other thread out of the plotter section.
I'd try a different blade degree, like a 32 or something. This should help your problem. Also, try test cuts first before cutting a whole pattern. Save yourself the material.
You might also make sure you have a good blade.
Try the guys a Clean Cut Blades in Iowa. Great knowledge and I just replaced my first blade after one year after using their blades. They give discounts for Tintdude members. Great knowledge about plotter settings to.
Hope this helps.
