Light solution mix vs heavy solution mix?
6
Electronic Malfunction From Tint?
It is very strange... I've yet to have that problem myself. You do need to he more diligent in your water management to assure less water usage. If they're trying to hold you liable, refer them to your insurance. Your insurance will investigate and deem who has responsibility. If they deny it, your customer deals with the insurance and you're out of the liability. -
70% Expel Plus on windshield ripple fix
Most likely a film defect or end of roll. One of the many reasons I wouldn't use Xpel. -
help arquitectural in Puerto Rico heat
Go with SolarGard TruVue 05. It's gonn be the best for what you're describing. Huge heat rejection, low heat absorbing to window. -
Flat Glass Installer NEEDED
13
4,171
