Dawn vs J&J
I use J&J for slip and dawn platinum to clean with. It says it cuts through grease and removes stuck on food.  That show that it cant be good for adhesive.  For removals i add extra dawn and soak the bg.  Definelty helps remove adhesive.
4 hours ago, TintDude said:
Between the two, I'd always go with the baby shampoo. Dawn is a bit strong with the grease cutter and can be too hard on the adhesive, but others say they have no problem with Dawn.
Have used dawn for years dawn simple clean non concentrate....tried baby shampoo just don't get clean installs with it.....use two bottles now one soapier for cleaning with alchohol and one with light dawn mix for install the trick is dont use  alot of dawn for install and always use distilled water no problems here....
39 minutes ago, Jkatfelix said:
I used Dawn for cleaning the other day and left the glass super clean ...I wanna say cleaner than j&j nice slip and easy to squeegee out
Definitely , tried  baby shampoo just can't get used to it I always get more specs for some reason?? They say it's bad for glue just don't use alot....oh and mix  with distilled  water!
Edited by quality tintz
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
