How long do you guys spend on a Side window hand cut???
Would like to buy a partial roll of the Solar Gard Supreme NR 40… needs to about 25ft x 30” plus and a 5% strip for the front windshield let me know if you could help out just a former window tinted here the has a new truck I wanna work on Thanks
