Last one to post #850
Got a call to do some windows... gave the quote back in early November. 56 windows... they wanna do 4 per month. :blink
Something about the budget. :dunno
Kindof sucks... gonna be a yr before it's done. lol
@jh812  If you want the easy replacement on those overhead bulbs...... look into " Line Drive T8 L.E.D. " bulbs.  You just remove the ballast from the existing fixture, and straight wire the new bulbs.  One fixture after a set of new bulbs will be as bright as 3 of the fixtures you have now.
The last one of those I did, I cut it exact and shrank it almost to the rubber about an inch and finished the shrink on the peel board by snap shrinking the top and bottom. I did have to heat out a few side fingers on the install though but they were minimal
@no ma'am
Not sure if it’s the same on other yr. models, but this one has a surprising amount of room on the inside (especially on the top). Most of the way down each side, there is a defrost terminal sticking above where you’d normally hide the edge beneath the gasket
I just gotta say ,,,,,,,,,
Prayers for Hawaii.   :mellow:  And all of our tinters down there.   :hide
Edited by Bham
Guest
This topic is now closed to further replies.
    2. 3
    4. 3
    6. 4
    8. 4
    9. 4
    10. 4
