Is this normal? Bubbles around edges after tint job
![Guest AJ33](http://content.invisioncic.com/r47004/set_resources_81/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
By
Guest AJ33
The direction of shrink
