Selling or buying a small business has numerous variables. Does the business own real estate ? Is it part o& the sale ? Is the owner staying on after the sale to help the new owner for any length o& time ? Does the business have any contracts in Que that will expedite the ROI ? Is there any inventory going with the sale ? Trade tools ? Web presence ? Does the business have employees that will stay on under new ownership ? .. Does the business have any agreement with any particular brand to offer their top tier materials ? IE Vista, Panorama, Etc. .. lots and lots of variables. But as a baseline, it’s not unreasonable for a business to be valued at 3-5x EBITDA. There are companies who can help evaluate the value of any business. -
8
Applying PPF profitable?
8
High speed material feed
Update to this.... We were using a Graphtec FC7000-100 plotter and the Digi Cut software and the machine wouldn't work correctly. We contacted Digi and they did a live modification on our software which solved the issue. Strange thing, the plotter would still never cut through the pattern consistently. (parts would cut totally through and parts would not cut even through the film) We switched to Core and instantly everything cut 100% consistent and without need for software modification. Perhaps if we had a newer plotter than the FC7000 perhaps the Digi would work as expected ??? Dunno
