Tesla mode 3 back window size
On 1/9/2020 at 5:40 PM, DynamicATL said:
No direct shots of the rear window.  Any regular dyed film like Llumar CTX in the photos above or Suntek Carbon is super easy.  You just need a 60" roll to cover the length of the window and you will shrink on the right/left side of the glass versus top/bottom.  It only gets harder when installing films like 3M Crystalline which just takes more time.  I do have a photo of the glass itself below.
Just a FYI to all of you.  If any of your customers come back with a crack originating from the bottom near the middle area.  Tesla will normally replace the window under warranty.  It's a known issue with these cars.  Probably from the large window not being able to flex enough.
And the fact the glass is actually 2 pieces of thin glass sandwiched together...so the thinness is a problem.
Does 48” actually fit the rear ? Always use a 60” but the actual glass is about 42”. Planning to order the 48”
