Tesla side door’s cracking
EZreach
We have tinted thousands of teslas model y and one Tesla s side doors cracked hopefully a bad batch but this is going to suck to deal with looks like they changed manufacture
Can you elaborate? What exactly do you mean it cracked? Was it while squeegeeing or just closing the door? I tint a lot of these POS. Yes I said POS these are the lowest quality vehicles on the market. They cut a lot of corners to make these vehicles.
Appears to be laminated glass with each glass layer being thin and prone to cracking easily with the right amount of stress in just the right spot. And, may not even be heat strengthened, if they like to cut corners.
Edit: Don't use any metal pull back tool for the weatherstrip at the bottom; it may crack this glass, too, if pressure is forcefully applied while the tool is touching the glass edge.
Edited by Tintguy1980
They have had their issues for sure but most manufacturers do, Honda alone just recalled 1.2 million vehicles. Ford is the #1 selling truck but commonly referred to "Fix Or Repair Daily" and "Found On Road Daily" for a reason. I won't even get started on Dodge.
    d2iwindowfilm.com
      Independent Contractors needed for Security Film Project- Houston
    5. 4
      Mutoh Plotter
      Reveal Molding/Belt Moldings
    8. 4
