what tint stripper do you use?
  • Replies 41
Jiffy Steamer, slip solution to soften. Sometimes I use simple pink with white scrubbies to remove glue from rear defroster windows using rubber gloves and covering the rear deck with towel or sheet and keeping it off of the side plastic pillar pieces.
@DynamicAppearance introduced me to rapid remover and it is the best adhesive remover out there. It won't stain panels and you can also use it for vinyl removal. I use Jiffy 4000i I think @jh812 told me that if I'm serious about window tinting, I have to buy a commercial steamer that will last long and do its job good. I use tap water..... should I switch to distilled?
For sure, distilled water only in your steamer if you want it to last.
