Raffle time, Stans Learning Library DVD set on tinting auto windows
8
Applying PPF profitable?
8
High speed material feed
2013 Suzuki Kizashi
Hi Bobby, sorry for the confusion, the makes and models section here is for tinting windows, not performance related. -
I sold my business in '96 that had as assets: tools and inventory and goodwill. I bought it 2.5 years earlier for 5k. It had a gross sales # around 30K and very little goodwill since the owner only worked it part time. In the 2.5 years I ran the company, gross sales went from 30K upward to 177K as a one person operation. To be fair, the final year @ 177K included an installation sale involving 35K sq ft. Still I increased the gross from 30K to 100K under my direction in the 2.5 years of ownership. I sold the business in a short sale for 10K because I landed a corporate job at a film manufacturing company. I lacked the desire to further expand the business, but it was considered reputable even by my competitors. One of them bought it. Don't know if that helps but, maybe you'll find this helpful in determining the goodwill of the one you are considering buying. https://www.freshbooks.com/hub/accounting/calculate-goodwill
