I think this is the second time we've entertained the wet shrink method with you and have recommended dry shrink. Wet shrinking is so old school it is like riding a horse as opposed to driving a car. There are many approaches to dry shrink compared to just one wet shrink. I'll just be blunt: move on to dry or continue to muck up film. Youtube is full of demos; words don't tell the whole story. -
8
Applying PPF profitable?
8
High speed material feed
2013 Suzuki Kizashi
Hi Bobby, sorry for the confusion, the makes and models section here is for tinting windows, not performance related. -
