Side swiper vs yellow turbo
18 hours ago, highplains said:
No it lacks the bead to hold it in the channel. I suppose you could try and clamp it in without the channel but it would be so floopy and unsupported that to call it useless would be something of a gross understatement.
you dont want to use this with the unger handle
On 12/9/2017 at 10:16 AM, Tint Slayer said:
Yes but i'm curious if the blue would be just as adequate at cleaning. That strip looks like it'd replace the black in my unger i use for cleaning.
it is not soft. the black is a cleaning blade. could be used for cleaning i suppose, but is designed to remove moisture. you been doing this a long time, i am sure you will figure what works for you
10 hours ago, drtint said:
I my opinion, Titan is great if used wet only. If you dint wet the inside of the window and heat an area on the outside, it will melt or make the soft red rubber disintegrate and mar the tool and round it off thus wearing it out.
I don't think your supposed to use any rubber squeegee without some moisture involved. Maybe i misunderstood what you're saying.
