Competitor False Advertising and Slamming Us. How to Handle?
Steer clear of Black Armour, Suntek, ASWF. The others are good choices if you are in Australia. Check out the reviews of the installer too. It’s not just the materials that have to be proper. Never go for the cheapest!!!
