The Tint Shop destroyed by tornado
35 years old. Over 10 years in the field doing automotive tint and ppf. Currently managing / working as main installer in Edmonton, Alberta. Xpel/Suntek, DAP/Core experience. Long story short, Canada became boring and i would want to give US a shot. Love what i am doing, getting paid well for where i am but i know i can do more & its hard to jump higher than your head where i am. if there are shops that are willing to provide i good Canadian installer a job offer i would like to talk. P.S. Would love to be in the place that is busy year round.
