Hey all, I am not a pro tinter but more or less just someone who likes to experiment / DIY. Wanted to ask if there was anyone here who has used the Geoshield "Geo" line for automotive purposes? I really like the color, but I get really bad ghosting for anything that requires decent shrinking. The film is specced as architectural, but has a PS adhesive so some use it in auto applications. I sent an email to see if that is the reason why it's for flat glass .. lol This is a sputtered TiN film and has a beautiful color imho. This reminds me of Huper Optik, and not quite sure but I think Johnson had a line called "InsulatIR" that I could never get my hands on to try. The film has a slightly purplish reflection (TiN I guess), when put on green auto glass, filters out and looks super neutral. ❤️ I've had it on my auto for a while but my rear window is a mess when the sun hits it (ghosting) and was curious if this is just not suitable for auto Any info would be appreciated. Skill issue, ie: shrink with lower heat? lol Thanks.
